MD Fuel PSI
Mixman
01-07-2006 15:55:11
What should the PSI be at the gauge on the pump on a MD.
El Toro
01-08-2006 05:41:50
 Re: MD Fuel PSI in reply to Mixman, 01-07-2006 15:55:11
My manual has that pressure at 45-50. Hal
n9lhm
01-08-2006 04:40:57
Primary pump relief valve opens at 35-40 PSI according to the book spec. Full scale pressure on the stock gauge might be 60 lbs. but it shouldn"t be that high when it is running. Brian
Ted in NE
01-07-2006 16:55:26
50 to 60 psi is ballpark ,will run on less
