MD overhaul
farmhand
01-07-2006 17:58:16
I have just completed a major overhaul on my MD and have been running it some in the shop to Iron out the kinks, but it still has some blow-by and slobering coming out the blow-by tube, and was wondering if I would have to pull the tractor a couple of hours to seat the rings to get this to stop or have I messed somthing up here. I have run it up to temperture and let it run for about two hours, or will it take more than that to do it?
Mcred
01-07-2006 21:07:33
 Re: MD overhaul in reply to farmhand, 01-07-2006 17:58:16
Hey farmhand we overhauled our SuperMD about four years ago and it still has some blow-by
and not much oil dripping out of the tube thou, you will want to put your MD on a good steady load for a while a half a day would not hert it a bit. These moters are harder to break in than a gas engine. good luck
billde
01-07-2006 20:18:13
You need to get a load on that engine asap, the rings won't seat properly until that happens. Put it on a dyno, feed grinder, something belt driven, or a drawbar load. Vary the rpms and load for at least a half hour.
Roger46
01-07-2006 18:11:48
I completely overhauled my MD several years ago. I have run it for quite a few hours and I still get blowby. I also get some oil dripping out of the breather tube. I think because of the high compression diesel you get more blowby than with a gasoline engine. Others may have comments also. Roger
