m timing
in oz
01-07-2006 18:36:19
help please is it timing or fuel,
i get no1 piston to tdc on compreesion and the first of the two marks is about 10mm out on pulley, when i install the mag the rotor arm is before no1 contact even advancing the mag its still out
if i try starting the tractor it just about runs with full choke and govenor open and wont pick up.
can anyone give me advice as to weather its something im doing wrong
in oz
01-08-2006 01:29:31
 Re: m timing in reply to in oz, 01-07-2006 18:36:19
thanks guys for getting back to me.
i did as magman said and it started and ran and it would rev, (choke about half) but opening the govenor to much the engine felt to get tight and stalled tried to re-start dosnt want to fire and kicks back blows smoke from air cleaner.
El Toro
01-07-2006 18:49:24
The first notch should be aligned with pointer when No1 piston is at TDC on the compression stroke. Then install the mag with the rotor at No1. Try this and see if the engine runs ok. You need to be sure you feel that compression against your thumb when you're on the compression
stroke.
Hal
MagMan
01-07-2006 18:45:43
This is what I do make sure #1 TDC compression put your timing marks on the first notch on the pulley go a little bit farther then trip the mag just past # 1 on the rotor make sure its # 1 compared to the dist cap. install mag.When you install the mag turn it as far toward the motor as you can. Then turn the motor over backwards about 1/2 motor revolution . Then turn it back with crank or something simelar untill you get the first timing mark on the pulley lined up . Then slightly turn the mag away from the motor untill it trips and tighten it up. JON
