What size socket?
Ben Rauls
01-08-2006 12:43:17
for the crank pulley nuton an M? Finally getting around to rebuilding it, and dont have a socket that big. Just figured someone knew off the top of there head. Thanks
Ben
Farmer Bob
01-08-2006 13:56:23
 Re: What size socket? in reply to Ben Rauls, 01-08-2006 12:43:17
My M's nut is also 2-1/2" I used a 3/4"drive socket set on mine to remove it. I suppose you could also use a pipe wrench set really snug to minimize the damage to the nut. Biggest open/box end wrench in my box is 2".
Ben Rauls
01-08-2006 13:59:03
 Re: What size socket? in reply to Farmer Bob, 01-08-2006 13:56:23
I tried a pipe wrench, didnt work, i'll go get a socket when i'm in town, thanks guys.
Ben
Bob M
01-09-2006 06:27:28
 Re: What size socket? in reply to Ben Rauls, 01-08-2006 13:59:03
Ben -
I purchased a 2-1/2" truck wheel bearing socket (heavy stamped steel socket) to remove the crank pulley nut on mine.
It's plenty strong enough - has worked fine on several different tractors. And the cost was less than half that of a "regular" chrome forged steel socket.
El Toro
01-08-2006 15:07:07
Use an air impact wrench to loosen that. I would get a 6 point socket too. Hal
El Toro
01-08-2006 13:10:08
The Super M use's a 2 1/2" socket, The M is probably a little smaller. If you have a pair of divider's you can use these to to determine the size. Once you have this measurement set it on a measuring tape. An old compass that we used as kids to make circles will do too. Hal
