super a head gasket
handyman33kev
01-09-2006 20:03:16
Can anyone help me? How do I go about replacing the cylinder head gasket? do i have to take the rocker arms off and reset them when I am done. also, how do i get the fan drive pulley off?
Red Dave
01-10-2006 05:29:37
 Re: super a head gasket in reply to handyman33kev, 01-09-2006 20:03:16
third party image
A pic of a setup to pull a fan pulley from a B. An A is done exactly the same way.
gene bender
01-10-2006 04:21:49
To remove the front crank pulley you need to remove the steering pedestal assy as the pulley will not clear the steering sector assy. Check the pulley as some had a set screw. They are a press fit and you need a three jaw puller with a bearing seperator behind the flanges of the pulley unless you want to break the flange on the pulley.
Mark in TN
01-09-2006 20:24:11
To replace head gasket you need to remove the head. You will have to remove the rocker arm assembly to get to the head bolts. There are just 3 bolts that hold rockers on the head. For the fan, there is a jam nut on the fan & water outlet bracket. Look on the fan spindle for a 5/8" wrench slot - loosen at this pont and jam nut will back off spindle.
handman33kev
01-09-2006 20:50:02
 Re: super a head gasket in reply to Mark in TN, 01-09-2006 20:24:11
thanks for your help. is this how you remove the main drive pulley though?
Mark in TN
01-09-2006 21:09:00
 Re: super a head gasket in reply to handman33kev, 01-09-2006 20:50:02
Yeah, once the jam nut is removed the fan & pulley assembly should come off the fan bracket.
handyman33kev
01-09-2006 21:14:23
 Re: super a head gasket in reply to Mark in TN, 01-09-2006 21:09:00
I have the fan off. I"m trying to remove the crankshaft pulley. sorry for the mixup.
Mark in TN
01-09-2006 21:26:10
 Re: super a head gasket in reply to handyman33kev, 01-09-2006 21:14:23
oh, in that case you need a big 2 jaw puller and a bearing splitter. Look a little further down the page for topic Scott#2 started titled "Tuff crank pulley hard to remove." The pulley will break if you put puller jaws on it. Put bearing splitter behind pulley with jaws of puller bearing on splitter rather than pulley. Some come off hard and others easy. I hope yours is easy!
