distributor or magneto?
bitbythebug
01-09-2006 20:14:17
I am currently restoring a 42'M. It has MW live hydraulics and a distributor that is mounted vertically on a ninety-degree-angle gear box. My step-brother has a 44'M, and his distributor is pointed straight back (horizontal mounted). Same as my step-fathers Super M. The question I have is, has my 'M been converted to distributor? If not, when did they quit equipping them with magneto's, or was ignition type always an option.
Thanx again,
Dan
NDS
01-10-2006 06:18:25
 Re: distributor or magneto? in reply to bitbythebug, 01-09-2006 20:14:17
The vertical distribitors are Delco aftermarket. On some of the live pumps vertical distribitor was required because distribitor cap would not clear oil filter with horizonal distribitor.
shoo_giesty
01-09-2006 21:32:33
the verticle distributor are used when you have a mounted corn picker. its a lot easier to access the points.
P Backus
01-09-2006 21:22:12
Battery ignition from the factory wasn"t available until at least "52, I can never remember exactly. All Hs and Ms had the H-4 magneto from the factory.
Paul
Andy Martin
01-10-2006 03:51:52
 Re: distributor or magneto? in reply to P Backus, 01-09-2006 21:22:12
I find this to be real surprising.
I thought battery ignition and lights were available from the first 1939 models and magnetos were available through at least the '50's.
I still prefer a magneto.
Nat 2
01-10-2006 05:20:28
 Re: distributor or magneto? in reply to Andy Martin, 01-10-2006 03:51:52
Magnetos were standard equipment on all non-Super letter series tractors, and even on some of the earlier Super As and Super Cs, if the timeline holds true.
Battery ignition was always an aftermarket add-on, a kit IH sold through the dealer if you wanted a "modern" ignition system. Supposedly the battery ignition was better, but other than being simpler and easier to maintain, battery ignition is inferior at what it was designed to do. A good magneto creates a way hotter spark.
Both M's in question here came with magnetos as standard equipment.
captaink
01-10-2006 06:03:20
 Re: distributor or magneto? in reply to Nat 2, 01-10-2006 05:20:28
I think one of the main selling points for the distributor was the fact that the impulse was not needed to retard the spark for starting. I realize that most of these probably came from the factory with starters (or “self-commencers” as my dad used to say) on them eliminating the hand crank most of the time. But, there was still the concern about hand cranking and that impulse not tripping correctly causing a kick-back and possibly injuring someone.
RustyFarmall
01-10-2006 05:19:17
Andy, a battery, generator, and starter were available from the factory in '39. You could also order up a "lights only" package, which included the lights and a sort of generator, but without a battery. Even with the factory starter and lights, the ignition was still a magneto.
Bob/Ont
01-09-2006 20:32:17
Likely after 1945 when batteries where more plentifull
Bob
01-09-2006 20:30:12
Your vertical Delco distributor is an aftemarket unit sold by the dealer, or a jobber.
