400 remote valves
scotc
01-10-2006 19:34:35
I found some sales literature for the 450 and it had something in it about how the valves could be switched from one-way to 2-way "with the flip of the wrist". I was wondering if the remote valves on the 400 could be switched as well. Ours has 1 2-way valve and 2 1-way valves. I'd like to put a quick-hitch on it this summer and would like to have 2-way operation on the hitch. Also are the valves difficult to rebuild? the 2-way leaks through enough that it won't hold up our 10 foot brushhog. Please email me with any info as I don't know how long it will be till I can get back here and see any replies. thanks.
scotc
01-11-2006 06:13:27
 Re: 400 remote valves in reply to scotc, 01-10-2006 19:34:35
thanks. I didn't want to pull the hood and turn the wrong thing, I know some of those parts can be expensive. See what i find when i get home.
Nat 2
01-11-2006 04:45:12
It's the same for the 400 and 450 as far as the procedure, except the 450 has holes in the hood, and the controls are extended for easy access. On a 400, you have to remove part of the hood to make the switch.
It's easy. On top of each of the valves is the control for 1 or 2-way. You use a wrench to turn the control 90 degrees to switch it.
MNredfarmer
01-10-2006 19:38:57
Yes, you can switch them on a 400 also. You have to take the right side hood off(as you sit on the seat). the 450 has a hole in the hood to switch one of them.
