SA Mag
banjo
01-10-2006 19:34:45
Need some info on how to change the coil on H-4 mag.
I rewired the tractor to run off the mag(had external coil). I do not get any spark with just mag, will run like a top wired with external coil.
Also need to check points, will it get out of time if i pull the large cover off. I peeked in the small cover under the rotor and I see some gears.
Looked for the marks on the flywheel but i can't find them to check the timing. Other Sa has the marks.But it is batt ignition.
Thanks
banjo
01-11-2006 08:22:56
 Re: SA Mag in reply to banjo, 01-10-2006 19:34:45
Finally found it, looks like somebody trained needs to do this. pictures are so dark .
With such a poor quality pics and not wanting to print correctly, looks like a disaster waiting to happen. Maybe i will back off and think long and hard on it.
MagMan
01-11-2006 14:58:55
 Re: SA Mag in reply to banjo, 01-11-2006 08:22:56
If you want to send that mag to me I usally dont charge an arm and a leg. Just both Golf Balls. LOL I usally get $50.00 Labor to do a complete rebuild + parts and shipping back of course. I should be able to do some mag work pretty soon. JON
MagMan
01-11-2006 05:39:10
I will tell you that you have to be exsremly carfull pressing the coil core in to the new coil. Sometimes they go like a knife through butter and you need to put asphalt on the core other times most of the time they dont go that easy and the core is very soft you can not pound on it and you can break the new coil very easy believe me its a real kick in the teeth when you break a $37.50 coil. That little cover you speak of with the gears it timed if you think the gears got out then it will need to be retimed. You can pull the 3 big screws on the front cover that holds the dist cap and pull it off exsposing the points with no problems. Just read the pages over and over in that online manual. JON
RustyFarmall
01-10-2006 20:48:41
Copy and paste
http://www.cleancomputes.com/Cub/Blue%20Ribbon%20Service%20Manuals/index.html
banjo
01-11-2006 07:41:43
 Re: SA Mag in reply to RustyFarmall, 01-10-2006 20:48:41
I tried that and nothing came up.Typed it in 3 times and the same results.
banjo
01-10-2006 20:25:05
Hey Rusty Farmall, where on line? Looked in the manual section but can't find any mag manuals
RustyFarmall
01-10-2006 20:45:58
 Re: SA Mag in reply to banjo, 01-10-2006 20:25:05
Ok, apparently I wasn't supposed to post the link here.
RustyFarmall
01-10-2006 20:14:29
The complete blue ribbon service manual for IH magnetos is available on line. Let me see if I can find it and I will be back.
RustyFarmall
01-10-2006 20:18:21
 Re: SA Mag in reply to RustyFarmall, 01-10-2006 20:14:29
Here you go, can't remember who put this up, but we owe a big thank you.
Bob
01-10-2006 21:38:18
 Re: SA Mag in reply to RustyFarmall, 01-10-2006 20:18:21
'twas just me!
