Sparks coming out of SH Alt.
Andrew Z
01-11-2006 08:28:28
Ok. I got my Super H all wired up with the diagrams found here. I fired it up and the battery was charging at 14.3 volts all good. Then after about 30 to 60 seconds the alternator beagn to spark out the back. What happend I thought that I had it??? Its a hitachi alternator if that is being used. Thnaks for the help Andrew
Brownie 45
01-12-2006 03:52:46
 Re: Sparks coming out of SH Alt. in reply to Andrew Z, 01-11-2006 08:28:28
More than likely, you will have a small piece of metal[ wire brush bristle, metal flake] lodged across 2 sections of the heatsink/ rectifier assembly. Had this happen on a Neihoff 24 volt alternator after putting in a new set of brushes. Never did figure where it came from.
Bus Driver
01-11-2006 16:52:39
To add to the discussion about alternator brushes, I have experience with several brands of import alternators. The Delco 10SI is by far the most durable alternator I have ever used. The Hitachi, Nippendenso, Mitsubishi, etc., are not as durable.
Andrew Z
01-11-2006 12:00:19
I looked again and I think that I got everything right. I went back and looked at previous posts and see that otheres have used some type of resistor in the syatem. Would this cause an issue not having this. The tactor has been converted to 12volts elctrontic egniton so I dont think that I need a ballast resistor. I used this diagram Link
Bob M
01-11-2006 10:16:51
I'm not familiar with the Hitachi alternator. I have however seen similar sparking from Delco and Mopar (Chrysler) alternators on several occasions. Some possible causes:
1 - A bit of conductive scrap (a strand of wire, metal filings, etc) got inside the alternator and has shorted across a heat sink, the brush holders, etc.
2 - If the alternator is used, the brushes may be worn out. When the brush springs contact the slip rings they'll burn. Sparks/bits of molten metal will then fall out of the backside of alternator.
3 - Could be you somehow got it wired up wrong and the sparking was the regulator doing a "melt down" thing. This however is unlikely since the alternator did work briefly.
Bob M
01-11-2006 11:21:22
 Re: Sparks coming out of SH Alt. in reply to Nat 2, 01-11-2006 10:48:43
Nat - Most alternators have brushes indeed! (Technically they brushes and slip rings - they feed current to the rotating field winding.) Only certain high output alternators such a used found OTR trucks etc. are brushless.
FWIW I was stopped by a state trooper late at night a few years ago to advise he observed sparks falling from beneath my van. Turned out the alternator was on it's last legs due to worn out brushes (the alternator failed completely only a a few more miles down the road).
captaink
01-11-2006 10:59:25
Yes, brushes in an alternator. They are used to transfer electricity to the rotating shaft or "stator" part of the alternator.
If they or the brush holder assembly (on a Delco anyway) are worn enough they can either hang up and not contact properly or as Bob suggested if worn away the spring will come in contact with the slip rings.
