Brakes on a 47 MD
Brad in WI
01-12-2006 01:48:46
Does anyone out there have the dimensions of the brake drum "rotor" I have the band brake setup not the discs like on the supers or "00" series. Mine is really chewed up and I am going to turn it down on a lathe. Also the correct size where the seal is supposed to contact the rotor. Thanks guys.
Brad
Brad in WI
01-12-2006 09:16:33
 Re: Brakes on a 47 MD in reply to Brad in WI, 01-12-2006 01:48:46
I figure I will try to clean it up first and then if I don't have enough brake I will go to a salvage yard and pick one up.
Brad
Haas
01-12-2006 07:02:55
Don't have any of those dimensions. However, why don't you try to get a replacement brake drum from a salvage yard. It should be easy to find one in decent condition. If you have to take much off the drum to clean it up, you are going to have trouble with the brake bands being too long, thus taking most or all of your adjustment.
