Farmall H clutch inspection plate
John in Ct
01-13-2006 09:19:13
I need what I believe is a felt for a Farmall H clutch inspection plate ( Part # 60181D) which is no longer available. What is a good substitute? Thanks!!
Randy-IA
01-13-2006 20:17:42
 Re: Farmall H clutch inspection plate in reply to John in Ct, 01-13-2006 09:19:13
Try using webbing like a piece of tiedown or seatbelt or you could find a old felt saddle pad and cut it out of that . You actually HAVE a cover ? I looked in the salvage yard last weekend for 3 hours and looked at at least 2 dozen letter tractors and didn't see any of them that showed sign of ever having one on . Ain't you a lucky one ! Good luck ...Randy
Bill Meinze
01-13-2006 16:46:50
Mine has had a cover plate since 88 without a gasket with no problems.
Andy Martin
01-13-2006 10:14:33
Are they supposed to have a cover plate?
