OS 400 update
MagMan
01-13-2006 16:31:02
Well the ol fella stopped by again today and said he got her apart and the nut came off the cam gear and ruined the gear.I still do not understand how it stayed in dist time but like I said before I dont know everything. any one got a heavy duty gear? JON
Bob M
01-13-2006 21:09:52
 Re: OS 400 update in reply to MagMan, 01-13-2006 16:31:02
Jon - I had the cam gear nut come off on my Super M. The nut broke the ends off several teeth on the cam, crank and governor idler gears on it's trip to the bottom of the gear cover. However the woodruff key in the gear hub kept the camshaft in time.
The loose cam gear sliding about on the camshaft camshaft made an ominous rap every 1/2 revolution, and this chewed up the gear hub beyond repair.
Carter & Gruenenwald had a new replacement cam gear - about $140 as I recall.
Janicholson
01-13-2006 16:53:07
When the gear spiraled outward, the relationship between the twwth stayed the same (just as it would with straight cut gear teeth) the teeth have to jump positions to cahnge the relationship between two gears in mesh with the moving gear. The timing of the cam gear itself would be changed, just not the others.
JimN
