Cover-All Building
Martin Reece
01-14-2006 10:39:45
This isn't really a tractor question, but I was wondering if any of you guys have , or installed a Cover-All building with the fabric top and 6x6 posts? Wondering about cost and how long the cover lasts. It would be used for a equipment storage shed. Do I need a building permit for this type of building? I am in Niagara Falls Canada. Any information is appreciated. Thanks in advance,Regards Martin
John in Ne.
01-16-2006 06:49:12
 Re: Cover-All Building in reply to Martin Reece, 01-14-2006 10:39:45
I wrote the check for mine Saturday,$28,274.Its 40x60x12,with a 12x10 overhead door and finished concrete floor.Wains coat and overhang with soffit added about $2,000.00 to the cost.Looks real nice.I getting it wired now,and have started moving my parts and pieces back from around the country. John.
Michael Soldan
01-14-2006 15:12:06
Martin, I built a pole shed 40x80,14'doors a nice looking building for $33,000. I still have to put a cement floor in it, or at least part of it to make a good work area. It is white with green trim, built with 6x6 poles, lots of room and well built to code. I have looked at those fabric topped buildings and for the money the steel building will outlast any. If you plan to have it for a long time I would recommend the steel deal. I have seen too many tops off on those other types. Esthetically I like the appearance of the steel building over the military looking buildings. I understand the tops have warranties but they range from 10-15 years, I'm thinking my building will be around long after I am gone...this is just my opinion ,cost them each way and get a read...good luck with your storage shed...Mike in Exeter Ontario
Butch WI
01-14-2006 11:59:52
Martin,
Priced out a 60x120 building only, about $70,000 US. Neighbor has an off brand one for a freestall barn. He lost the top twice in three years. He does a nice job so I think it may have been design flaw, or it was that we had straight line winds both times. He has now covered it with steel using some sort of purlin.
Butch
Brad in WI
01-14-2006 10:46:24
I hear that the hold up really well if kept tight. They have ratchet mechanisms to increase tension on them. the fabric will cut/tear if a sharp corner is rubbing against it also. I am not sure about the cost, some friends just built one 60X100? and I think it cost around $100,000 US. But that also included concrete and installing freestalls. You will have to check with the local laws about a building permit. I think that you would have to but I may be wrong. My .02 cents worth.
Brad
