Carb diffrence.
Andrew Z
01-14-2006 12:55:24
I was wondering is there any diffrence from the carb that is used on a Super H, is that same one used on a M or Super M? Andrew
Andrew Z
01-14-2006 16:03:32
 Re: Carb diffrence. in reply to Andrew Z , 01-14-2006 12:55:24
Thanks guys I was just wondering what the diffrence was. seeing that the outside was the same. Andrew
Bob M
01-14-2006 14:26:56
The SH and SM carburetor main castings (float bowl and throttle body) are the same and will fit both the SH and SM manifolds.
However the SH and SM use different venturis, main and idle metering jets, main fuel discharge jets, etc.
CNKS
01-14-2006 13:00:49
They will be jetted different, I don't know about other differences, not sure if a M/SM will fit a SH manifold.
RustyFarmall
01-14-2006 14:50:49
 Re: Carb diffrence. in reply to CNKS, 01-14-2006 13:00:49
Yes, all of those carbs will interchange as far as bolting up. Like Bob M said, the differences are inside.
