Farmall 230 hydro questions??
T.r.y.
01-14-2006 22:16:34
Hello I'm can't seem to find the sight check and the fill plug for the hydro unit. Its not the same as the super c's. I think I have a pump shaft seal leaking into crankcase. Any helpful hints?? thanks take care.
BobG in VA
01-15-2006 08:29:41
 Re: Farmall 230 hydro questions?? in reply to T.r.y., 01-14-2006 22:16:34
The fill plug is located on the left/center side of the torque tube just in front of the hydro block (same side as the serial # plaque). Check with flash light or finger. Should be 1/2 inch below the fill hole. Drain plug is on left side of hydro block at the bottom. Good luck! BobG in VA
t.r.y.
01-15-2006 17:27:16
 Re: Farmall 230 hydro questions?? in reply to BobG in VA, 01-15-2006 08:29:41
Hello thanks for the info. I see exactly what you talking about. Is the torque tube serve as a resivior for the hydraulic fliud for the system. I was thinking it would be on the hydro valve unit right under the gas tank. I actually had a pump seal blow and lost all hydro fluid in the crankcase. any how thanks for the help.
