will super m piston and sleeve kit fit in a regula
Curt Booe
01-14-2006 23:18:23
i was wondering if a super m piston and sleeve kit would fit in a regular m block without machine work? my m right now has high comp. 4 inch pistons so i wasnt sure of the difference. thanks alot!!
MagMan
01-15-2006 00:33:47
 Re: will super m piston and sleeve kit fit in a re in reply to Curt Booe, 01-14-2006 23:18:23
That all depend on if its a 4" or 4 and 1/8" if its a 4 1/8 no the block would have to be bored. My SM has 4" fire crators in it. So the 4" would work. JON
Dave Slater
01-15-2006 04:41:23
 Re: will super m piston and sleeve kit fit in a re in reply to MagMan, 01-15-2006 00:33:47
Magman, SM sleeves will not fit a regular M block without machine work whether the SM sleeves
are 4 or 4 1/8 ID. Pistons are a different story.
MagMan
01-15-2006 05:21:07
 Re: will super m piston and sleeve kit fit in a re in reply to Dave Slater, 01-15-2006 04:41:23
I thought about that after I posted but was not sure it was in the middle of the night could not sleep I just figured 4" was 4". JON
JakeF
01-15-2006 11:16:18
 Re: will super m piston and sleeve kit fit in a re in reply to MagMan, 01-15-2006 05:21:07
An M has 3 7/8 pistons and a 4 1/8 bore in the block.A super M -400 has 4" pistons and a 4 1/4 block bore. A 450 has 4 1/8 pistons and a 4 1/4 block bore. You can put 4" pistons in an M but you use thinwall sleaves made for the M block, just as the 450 has thinwall sleaves made for the 400 block. Or you can bore your block .125 and use the 4 1/4 OD 450 sleave set. You can also run 450 sleaves in the M block without sleaves. Jake
