Casting date code ?s
Brad in WI
01-14-2006 23:18:49
Can somebody tell me where to find the list for what letter was for what year that IH used on their castings. Or even give me a list. Also where would the engine serial number be on a MD. Looking into doing a little research about mine and need to know where to find the info. Thanks
Brad
FarmallDude
01-15-2006 15:30:52
 Re: Casting date code ?s in reply to Brad in WI, 01-14-2006 23:18:49
Brad: here is a link for the IH Cast Dates... FarmallDude
Link
Brad in WI
01-15-2006 13:50:06
 THANKS GUYS in reply to Brad in WI, 01-14-2006 23:18:49
Thanks for all of your help. It is great knowing that there is still a good group of people out in the world that are willing to assist others when in need of finding/doing something.
Brad
ejr-IA.
01-15-2006 10:52:51
Go to research and info,click search this site,type in IH cast dates.go down this list to IH cast dates posted by Milton.
Brad in WI
01-15-2006 09:59:43
I know that my MD is a 1947 I just wanted to know about the casting code letters. Some of my castings are early in the alphabet and then again some are later in it. Just wondering how many pieces could have been changed throughout its life. Also I was wondering if the engine serial number matched the chassis number. Thanks for the help
Brad
CNKS
01-15-2006 10:57:11
 Re: Casting date code ?s in reply to Brad in WI, 01-15-2006 09:59:43
Engine serial won't match the chassis. Unless your tractor was built early in the year it is likely (but not an absolute sure thing) that all original parts will have the same letter for the year. Usually they will vary only 2 or 3 months.
Brad in WI
01-15-2006 11:29:07
 Re: Casting date code ?s in reply to CNKS, 01-15-2006 10:57:11
Where would I have to look on the engine block to find the hand stamped serial number. Just curious to what it is.
Brad
Dave Slater
01-15-2006 15:38:20
 Re: Casting date code ?s in reply to Brad in WI, 01-15-2006 11:29:07
Engine Serial # is at front left side of block
above injection pump and just below head.Flat place there,may have to scrape to find.If original
block the date code will be near top rear corner
of injection pump or little behind pump.Some diesel will have engine block date 6 months or more earlier than other castings.
CNKS
01-15-2006 13:01:29
Assuming the diesel location is the same as gas, under the #1 spark plug.
Greg-N-CA
01-15-2006 06:39:36
In the future, just use the "Research and Info" gallery on the right side of this page. The information you are seeking is under "Production Nbrs" and "Serial Numbers." Good luck, Greg
Dean E MINN
01-15-2006 04:12:36
IN 1931 they started with the letter A, going thru the alphabet 12-30-A your MD could be 12-31-X meaning December 31 1952 they used U&W for 1951.The location is left side of the clutch housing for the chassis number and top milled section of the left side of the crankcase is the engine number the first md was FDBK 26,145 built Jan 13-1941 this info I got out of a Int-Harv Tractor Data book put together by Guy Fay I got my book at a tractor show.It has a whole group of good info in it.Good luck Dean Minn
