Farmall 200 steering question
Jim in Michigan
01-15-2006 09:23:10
I have a Farmall 200 that belonged to a friend, he passed away and I bought it,,I paid too much for it, but thats ok,,my problem is the steering, it will only go one direction, its a wide front, any ideas? Thanks,,Jim
Janicholson
01-15-2006 09:44:42
 Re: Farmall 200 steering question in reply to Jim in Michigan, 01-15-2006 09:23:10
Not sure but first guess.
Someone took off the steering arm from the shaft and put it on incorrectly so that only about 1/2 of the sector travel is available. I would remove the arm and check wheel movement to see if it is now full turns.
JimN
Jim in Michigan
01-15-2006 09:48:27
 Re: Farmall 200 steering question in reply to Janicholson, 01-15-2006 09:44:42
thats a good idea.. he replaced the whole bolster and steering after a accident in the field, then it wouldnt steer right,,Thanks,,Jim
