Are John Deere Rear Rims interchangeable on H??
Scott Rong
01-16-2006 01:58:34
Hi, Just saw an ad on some Rims that came off a John Deere A, and the seller said they would fit an H or M Farmall. Do those Rims interchange with a Farmall H?? Size of Rim is 13.6x38 inch
Thanks,
Scott
Des Moines, Iowa
Nebraska Cowman
01-16-2006 03:16:54
 Re: Are John Deere Rear Rims interchangeable on H? in reply to Scott Rong, 01-16-2006 01:58:34
yes, the A & B Deere rims are the same as the H & M Farmall except for the green paint. They are the deep-center rims
Hugh MacKay
01-16-2006 03:01:22
Scott: I know rear rims will interchange after you get into later models with double bead rims. IH started using double bead rims on Super letter series, I expect Deere was about the same time, early to mid 1950s. I suppose they both could have been using same rim before change to double bead. Best to take a tape measure and look at an old Deere, compare it with yours.
I bought a set of double bead rims for my Farmall 300. They came from a Cockshutt dealer going out of business. New rims painted the yellow for 550, yet the exact rim IH were using. I know Deere rims from mid 60s would fit my 560 or 656.
