Electronic ignition question
T.B.W.
01-16-2006 07:11:26
I know electronic ignition will make it start better, but will make the engine run better. I have a miss under no load on a M. With new points it seems to be better. Will electronic ignition smooth it out or do I need to look at valves or manifold?
John T
01-16-2006 07:58:57
 Re: Electronic ignition question in reply to T.B.W., 01-16-2006 07:11:26
TBW, Good question for discussion. Theres only so much an electronic or any ignition can do as far as "making a tractor run better"
Theres good truth in what you say about helping them "start better" because at cranking due to the battery voltage being reduced, whatever increased/improved spark energy they can deliver versus a point ignition is of good and maybe more noticeable consequence. However, once running and the battery voltage is back to normal, they can still deliver more spark gap energy then a points ignition, BUT THE IMPROVEMENT MAY BE LESS NOTICEABLE THEN (likely still some improvement if on a Dyno).
Where they can help once running and their improvement is maybe more noticeable (due to their ability to discharge more energy across the plug gap) is in the cases where a spark plug may be fouling out with a points ignition. THEREFORE if due to low compression or oil fouling or running too rich etc its a plug fouling thats making a tractor run bad, an electronic ignition can GREATLY IMPROVE PERFORMANCE i.e. make them "run better" cuz the plugs dont get fouled so soon or easy.
I guess what Im saying is. They can indeed improve starting performance,,,,, ,and ifffff she has low compression or is an oil burner or running too rich which tends to foul the plugs, AN ELEC IGNITION CAN MAKE HER RUN BETTER cuz the plugs are harder to foul (potential fouling deposits get burned off) HOWEVER if shes in tip top shape and although an elec ignition may still produce a few more HP on a Dyno, the improvement is less noticeable.
If she an oil burner YES an elec ignition will make her "run better" simply cuz the plugs dont get fouled so soon or easy.
Best wishes n God Bless
John T, retired electrical engineer in Indiana
T.B.W.
01-16-2006 13:37:06
 Re: Electronic ignition question in reply to John T, 01-16-2006 07:58:57
Thanks John, It does burn a little oil and may be to rich also, so I think the electronics may be worth the $ Thanks. Tom
