Super C TC Pump
SuperCDon
01-16-2006 13:27:54
third party image
A couple of weeks ago I posted a question regarding the part # for the seals for this TC Pump # 355007R92. I received several replies and one told me the parts I was looking for were from Gasket Kit 355207R91. I ordered part #s 353836R1 (shaft O-ring) and Body Seal # 353185R1. The O-ring will work, but the other doesn't. Does anybody konw the part the number for the body seal shown in the attached photo as Part #4? I also posted the photo in the "Parts and Pieces" photo gallery on this forum.
El Toro
01-17-2006 04:32:32
 Re: Super C TC Pump in reply to SuperCDon, 01-16-2006 13:27:54
Hoober will need the number from the pump itself.
it should start with a zero. Hal
SuperCDon
01-16-2006 13:31:54
 Photo of Pump Drawing in reply to SuperCDon, 01-16-2006 13:27:54
third party image
I'll try again to post the photo with the above message.
El Toro
01-16-2006 16:48:30
 Re: Photo of Pump Drawing in reply to SuperCDon, 01-16-2006 13:31:54
My IH manual has the same parts breakdown as yours. I have another view of that shows the whole pump including the drive gear that isn't shown in the manual that's why there's more part numbers.Hal
El Toro
01-16-2006 16:39:42
I have a breakdown on a Pesco pump and it shows that body seal ring as being P/N 13. It may be the same item as yours. Call 1--800-732-0017 and ask for farm tractor parts. Hal
SuperCDon
01-16-2006 17:30:09
 Re: Photo of Pump Drawing in reply to El Toro, 01-16-2006 16:39:42
What is the Pesco Pump number that goes with P/N 13? What company is the 800 number for?
El Toro
01-16-2006 17:59:19
 Re: Photo of Pump Drawing in reply to SuperCDon, 01-16-2006 17:30:09
My drawing doesn't have a pump number and the
800 number is for a Case/IH dealer in PA. Hal
CNKS
01-16-2006 17:25:01
Toro, what company is that number for?
El Toro
01-16-2006 18:04:40
 Re: Photo of Pump Drawing in reply to CNKS, 01-16-2006 17:25:01
It's for Hoober Equipment in PA, that's a Case/ IH dealer. If it's available they'll get it out of their warehouse. Hal
CNKS
01-16-2006 14:29:42
IH says you can't buy that part unless you buy the whole kit, at least when my manual was printed. There were both Thompson and Pesco pumps, it should say on the pump which you have. I have a C, not a Super C, and the numbers you gave are not in my book -- If someone has the proper manual, or look at it at your CIH dealer, or call Carter and Gruenewald. Unless the old seal was leaking, it may be ok anyway.
