Remote hydraulic valve
wsmith
01-17-2006 08:48:12
I checked through the archives and can't find much info on these remote hydraulic valves for the tranny driven lift-all. this valve gives both up and down pressure to the lift-all to operate a 2-way cylinder. My local CASE dealer doesn't seem to want to help much. The remote valve still works but "squirts" fluid from around the control rod when the lever is released back to the hold position. Is there an o-ring type seal on the spool and if so, will that fix my "squirt"? Sorry for the long way around the question and thanks in advance.
Jeff Grodey
01-17-2006 13:26:46
 Re: Remote hydraulic valve in reply to wsmith, 01-17-2006 08:48:12
I took mine apart last weekend because the spool froze up. There is only one o-ring seal. You may also have to make an adjustment on the screw that runs through the middle of the spool. This controls how far the spool travels inside.
Because mine is so messed up, can you tell me what hose hooks up to what hole on the valve? There are three outlets. Mine has the middle outlet going back to the cylinder and the two on the outside have one hose connected to both holes, so that it goes right back into itself. Is that right? Thanks...
Hayfarmer
01-17-2006 12:39:44
I rebuilt one of these valves a few years back. There shouldn't be oil up high enough to squirt or even run out of the area around the handle. There were either 1 or 2 o rings on spool. If you take it apart you can probably match them up most anywhere.
Nat 2
01-17-2006 12:35:30
There's not much inside. You can easily disassemble the valve and check the condition of whatever seal is used there..
