Tell me about the rod pin bushings
Kelly C
01-17-2006 16:51:52
C263 copper pin bushing in the rod.
How the heck you get them out and get a new one in?
Aces
01-18-2006 08:06:18
 Re: Tell me about the rod pin bushings in reply to Kelly C, 01-17-2006 16:51:52
Kelly The only thing I would add they should be line bored so they are in line with rod bearing or the piston might not be straight.
lee
01-17-2006 17:00:10
Those need to go to an automotive machine shop. Old pressed out, new pressed in and then honed to your new pin size. You have a new sleeves and pistons/pins kit I assume. You won't want to be welding any key stock on a small plate and hoisting those out.
the tractor vet
01-17-2006 16:59:11
With my bushing driver and the press then when ya put the new ones in they have to be honed on a pin fitter it is one of them things that don't try this at home childern leave this to the trained professionals.
Kelly C
01-17-2006 17:13:19
 Re: Tell me about the rod pin bushings in reply to the tractor vet, 01-17-2006 16:59:11
OK. Thanks.
