International 826
Doony
01-18-2006 21:41:07
I bought the 826 I was telling you about but there are two lines under the radaitor that leak oil real bad what are the two lines and a where can I fill it at and what to fill it with? I need to load it and unload and don't want to hert anything. Thanks alot
wolfman
01-19-2006 17:25:40
 Re: International 826 in reply to Doony, 01-18-2006 21:41:07
If they are steering lines, could you duck tape them to get it loaded? Make sure Hydraulic-Transmission oil is on the dipstick.
Weldon
01-19-2006 08:04:24
As tractor vet said, they are lines to power steering. New ones should be available from Case/IH dealer. Or look for a good hydraulic hose fabricator/repair shop in your area. Many such shops can fabricate steel tubing hydraulic lines identical to what you need . Just take yours to the shop for them to use as a pattern. I have found it to be less costly than dealer.
the tractor vet
01-19-2006 06:24:47
Well if they are UNDER the rad then they are your Steering lines and it is not uncommon for them to rust thru on tractors that have not been taken care of . So you will have to replace them with new lines or good used one . Now if the leak is up on the top left then they are your oil cooler lines and they are low pressure Hdy. rubber lines and just may need the claps tightened or the lines may be hard as a rock and need replaced ( DON'T cross them when replacing them . And ya fill the hdy oil thru the dip stick in the floor plate buy you right foot ( don't pull that dipstick out with the engine running and try and put it back in you stand a real good chance that you will get into a couple of gears in the transmission and it will not only EAT THE DIPSTICK but break gears. And it takes HY Tran.
Allan in NE
01-19-2006 03:23:47
Tell me about it. Is it leaking this bad? :>)
I ran all new hydraulic hoses out to that cooler and poured in new oil. Hardest part was chokin' down the cost of that hose.
Allan
third party image
Kelly C
01-19-2006 03:46:05
 Re: International 826 in reply to Allan in NE, 01-19-2006 03:23:47
third party image
Geeze for a secound there I thought we had the same girl. I thought I was the only one who could see her naked.
Cusins I guess.
Oh the 2 upper lines are oil cooler lines. The 2 lines on this side along the frame rail are the steering lines.
Quebec Red
01-19-2006 09:25:40
 Re: International 826 in reply to Kelly C, 01-19-2006 03:46:05
Naked cousins..... perked my interest,..for a moment....
donny
01-18-2006 22:16:40
Thanks K.B.-826
K.B.-826
01-18-2006 22:01:33
Sounds like you're talking about the power steering lines. Transmission/Hydraulic dipstick is located about where your right foot would be while sitting on the seat. Fill until it at least touches the stick with a good quaility hydraulic oil, such as Case-IH Hy-Tran. Once you get those lines fixed, drain the transmission, change the filter, and refill with new fluid. Holds about 17 gallons.
donny
01-19-2006 20:23:49
 Re: International 826 in reply to K.B.-826, 01-18-2006 22:01:33
Thanks to everyone
