H Block Plugs
John London, Tx
01-19-2006 16:36:13
Found a block today to replace one with cracked cylinder wall. The freeze plug just above the rear crank bearing is eaten up from rust. The cap over the cam looks solid, and there are two additional plugs (one front and one rear) at the top of the block that appear to be solid. Is it advisable to replace all plugs while its torn down? Are the two plugs at the top of the block also freeze plugs? Haven't been this deep in an engine before so will try limiting dumb questions during the overhaul attempt! Thanks
randy hall
01-19-2006 19:12:38
 Re: H Block Plugs in reply to John London, Tx, 01-19-2006 16:36:13
there is no such thing as a 'freeze plug'. these are places in a complex casting that had a support to hold the core box during the casting process. and yes it would be a good idea to replace all of the soft plugs.
john savoy
01-19-2006 17:05:17
Sounds like the upper two are also freeze plugs,as with every thing else change it all now,no problems later,
Janicholson
01-20-2006 06:06:59
 Re: H Block Plugs in reply to john savoy, 01-19-2006 17:05:17
If they were freeze plugs then they seem to be very poorly designed or placed. They are core plugs, as Randy points out. While doing it why not put in a block heater?
I like the non rubber expandible plugs beacuse they are easier to assure proper seal.
JimN
