Super H fan
Dave Wilt.
01-19-2006 19:30:15
I am missing the fan shroud on my Super H. I see that there is two diffrent types of shrounds. Ones that went for H's and the other 300, 350. My Super H was made in late 54. what one do I need and where is a good place to get one?
Dave
CNKS
01-19-2006 19:40:12
 Re: Super H fan in reply to Dave Wilt., 01-19-2006 19:30:15
Parts book shows a different part number for H shourds after H SN 261000+. Super H uses the same one as the late H -- I imagine either will fit. Call Mike Bunck at Steel Wheel Ranch, he will likely have one and know if there is any real difference 785-548-7437.
Nat 2
01-20-2006 04:53:54
 Re: Super H fan in reply to CNKS, 01-19-2006 19:40:12
Believe me, there isn't any difference. Same radiator, same shroud. Very little ahead of the bell housing is different between a late H and a Super.
CNKS
01-20-2006 05:48:52
 Re: Super H fan in reply to Nat 2, 01-20-2006 04:53:54
They likely fit, but the part suffix is different, meaning they are not absolutely identical. Newer parts are usually downward compatible, but in this case the old one has an later suffix (higher alphabetical) than the later. I'll compare my 41 H and 53 Super H sometime.
