966 for brushhog
Rifman
01-20-2006 14:58:56
I may be able to purchase a reasonably priced, well maintained, 966 (non-hydro) for brush hogging work. I only own 12 acres, but I will also be hiring out the tractor with an 8 foot brush hog. My questions are:
1) Is this tractor really too big for this kind of work?
2) Is this tractor a good rugged design, or is it maintenance heavy? 3) What hidden problems should I look for in this tractor?
Any comments will be appreciated. Thank you.
Randy-IA
01-21-2006 20:49:01
 Re: 966 for brushhog in reply to Rifman, 01-20-2006 14:58:56
Hi , I don't have the lifelong experience that some of the others that have responded do , nor do I write as well . But I just bought the farm I'd rented for 17 years and and doubled the acres to 13 then started to make hay last year . I made the mistake of buying a " too large " tractor . A Oliver 1775D ( 86 hp ) that I had to put over 3 grand into within the first couple of months . I really love driving this thing though ! It's just too darn big ( 13,000 lbs ) to make tight corners with the 990 moco or the 415 Oliver sickle and the rear tires tear up a lot of turf in the corners . If I could afford to do it over I'd have looked harder for a 1655 Gasser or a 400 or 450 with a narrow front . But hindsight is always 20-20 vision . But to be honest , even with a 13,000 lb tractor with fluid in the rear and no front weights the front got REAL light with a 8' 3ph rotory cutter ( Rhino ) on the back up in the air during transport . So last fall I got a M . I love driving it too ! Even with all it's faults . It's got the 9-speed transmission add on and it travels only 2 mph less than the Oliver in road gear . I haven't used it yet for anything more than pulling a 30' spike harrow so my jury is still out . I hope it'll handle all the hay duty except when it'll be running the elevator to get the hay in the mow . Soo... good luck with your decision ! ...Randy
PS ; I don't do this ( hay making ) with an eye to making a profit on everything because like sports cars or motorcycles the prospects of getting a return on investment is dismal . For 12 acres you might have to remember that you aren't going to get much back for your time and investment so to recoop the price of an expensive tractor may take years . It's mostly for the fun of it .
scotc
01-21-2006 08:18:06
I can't agree with everyone here every way. Yes a 966 may be overkill for an 8 footer, as our 400 is handling a 10 foot pull type, but not always all that swiftly. Yes, a 560, a 6- or 7- 06, 56, 66 would be a little better sized. But that 9 will probably hold up a lot better by not being pushed to the max all the time. And I never saw grandpa's 9 or either of our 10's or 1566 suffer from lack of being overworked. And I've only seen our 786 push oil out the exhaust and that was a subzero day when my dad left it running at a dead idle. Fuel use on that 966 shouldn't be too bad because running at or just over pto throttle the governors shouldn't be kicking fuel to it all the time. And you are going to be hiring out, so you won't just be running 11 acres. Plus last I checked 3 pt brushhogs aren't all that great for holding front wheels on the ground so the extra size of the 966 will help there also. The only thing there is that if you get stuck by some freak accident (which never, ever happens to anyone, I'm sure) it will be harder to pull out.
Cliff Neubauer
01-21-2006 05:50:18
A 966 will work just fine for what you want to do,it may be a little bigger than you need but that's not going to hurt a bit. We have three 1066's that see mostly light duty work, bush hogging, haying and running augers and it doesn't hurt them a bit. As our farm has grown the 1066's have gone from major field work tractors to planter tractors and now more or less to chore tractors that can be used for field work if we need them. The third 1066 is one we just bought off a neighbor and it will get a very easy life but it was a one owner black stripe model with less than 1,800 original hours and with a good wax job it will look like it just rolled off the assembly line. Our 1066's will use about 3 gph of fuel when mowing hay with a 9' disk mower so your not going to use much more fuel than a smaller tractor.
Baelee05
01-21-2006 04:56:39
Rifman, There is absolutely nothing wrong with using a 966 to brush hog. A little bit of overkill? Yes I suppose it is. But so what? You are gonna use some extra fuel compared to the coveted 60 hp tractor that others speak of. If you have the 100 hp tractor you will have extra power if you upgrade mowers or buy another piece of equipment that requires more hp. Make damn sure the tractor is in tip top shape. As Hugh mentioned repairs on these tractors can get expensive. If the tractor is in good mechanical condition when you get it the amount of repairs that you will need from brush hogging with it are minimal. This notion that you have to use a tractor to its maximum hp potential or you shouldn't own it is crap. This is a hobby for most folks on here. Hobbies most generally aren't economical. You don't have to work a tractor so hard you pull the guts out of it for it to run right either. In fact with the 966 and the 66 series in general your repairs using them at below rated hp are going to be a lot less than if you are working the crap out of them. Anyone who had a 66 that they worked really hard or had the pump turned up usually ran into big repair bills. Even with excellent maint. If you could find a 706 or 806 it might be a better choice. They were more durable. For what you want to do the 966 will be fine. You just need to be aware that it won't be as efficient as a smaller tractor. If you can get a good deal and the tractor is in real good shape, go for it! Good luck.
Hugh MacKay
01-21-2006 06:07:24
 Re: 966 for brushhog in reply to Baelee05, 01-21-2006 04:56:39
Baylee: BULLFEATHERS, My 1066 hit the 10,000 hour mark by the time it was 8 years old, actually not quite 8 years by the calandar. It required an engine rebuild at that time, nothing more. Since coming to YT some 5 years ago, I can't begin to count the numbers of 966, 1066, 1466, etc. I've seen requiring major rebuilds at less then 5,000 hours and they are now 30 years old. And by major rebuilds these guys are now talking engine, TA, transmission and rear end plus hydraulics. Who had the most economical horsepower? Sure you can find a good looking 966 or 1066, but a drive around someone's yard will not pick out all the things wrong.
Just look at Allan, he had a 966 new 30 years ago, and he bought a 30 year old 966 just last year. I think he is just about as qualified as anyone to spot something wrong on the drive around. I have no question with his credentials on that one. However, just look at the items he's found wrong with that 30 year old 966 since he started working it.
Even my lowly little Super A, probably one of the top ten Super As mechanically across North America, and it has always been that way. Up until 5 years ago it was used commercially. It doesn't have an hour meter but can't remember a year it didn't get enough use to burn 500 IMP gallons of gas. Now it burns about 30 gallons per year mowing my grass, and I fix just as many items every year as I did back 10 years ago. Are you trying to tell me the annual parts for my SA will cost as much as a 966?
Baelee05
01-21-2006 10:58:26
 Re: 966 for brushhog in reply to Hugh MacKay, 01-21-2006 06:07:24
Hugh I don't know why you have to take it so personal when folks want to use an older "big" tractor for some light work. If the guy has the money to maintain the thing so what? Its no skin off my nose or yours. He may be well enough off he doesn't care about the bills. You assume every 9 or 1066 on every lot or farm is on the cusp of needing a front to back overhaul. That is not true. There are plenty of those old tractors that have had an easy life and good care that will last a long time yet with little $$ spent on them. I should think brush hogging will bring on a lot less repairs than heavy work. As for your argument about your Super A and the repairs on it versus a 966.....Get real. The guy doesn't want to live on a Super A all summer long to do his 11 acres and custom work. Sure your Super A will need fewer dollars spent on it but I think time is a big consideration for the guy. Just where in my post did I suggest that this man buythe tractor based on a drive through the lot? I told him he had better make damn sure the tractor was in top condition or he COULD be looking at big repairs. I have followed the saga of Allen's 966 closely. I saw pictures of Allen's tractor when he bought it. I believe he bought it with the knowledge that it would need extensive repairs. His choice. I think he could have found a 966 in a lot better repair and ended up spending a lot less money in the end. Good day.
Hugh MacKay
01-21-2006 15:52:58
 Re: 966 for brushhog in reply to Baelee05, 01-21-2006 10:58:26
Baylee: While I agree with much of what you are saying, I guess I tend to be a bit cautious giving out advice to guys buying tractors. One is never absolutely sure of the guys ability to spot problems. Then as you pointed out we just never know for sure whether the guy is operating on a shoe string financially or can afford to start the morning fire with $20. bills. There is also quite a range in between the two.
I'm not suggesting he try to do his bush hogging with a Super A. They are quite a little tractor but you got to draw the line when it comes to PTO work. I was just merely pointing out that even parked these tractors are not trouble free.
I also suspect that large chassis 06, 56, 66 and 86 series tractors are far more plentiful where you come from than around here. Oh we had them once, but when the Canadian dollar was about .65 US, just about every decent Farmall or Deere for sale went state side. That went on for about 20 years. They were also selling new ones here for about 25% less than in the US. using a common dollar. I know a dairy farmer bought a new CaseIH around 1992. Two years later he decided to get out of the dairy business. At his auction that tractor brought $2,000. more than he paid for it new and the buyer was American.
You may think I was a bit personal, however I think it was important he see all sides of the argument. As a group I think we suceeded. By the way the tractors are moving north this past year.
Baelee05
01-21-2006 17:16:29
 Re: 966 for brushhog in reply to Hugh MacKay, 01-21-2006 15:52:58
No doubt about it Hugh. You folks up north have always made better use of your horsepower than a lot of us here in the midwest. For as long as I can remember a lot of guys have been overpowered. Especially in the 1970's when things were pretty good. There were a lot of 966s in this area that never did much besides plant corn. No offense taken. I hope I didn't offend you either.
Allan in NE
01-21-2006 06:26:43
Yes Sir,
Sometimes, I think it is a cursed detriment. Havin' had 'em new, I now compare everything to that memory of how they were then.
Nobody can hear this noise in the rear end of my tractor except me, but I know they didn't talk like that when they were new.
So, since I've already dumped $14K in this old tractor, I'll probably go ahead an pour in another $5K just to make it right and to satisfy my own silly mind. :>(
But Damn! I do like this old devil! :>)
third party image
Allan
Allan in NE
01-21-2006 05:35:57
Mornin' Baelee,
'Course there's nothin' "wrong with it". He can hook that little eight foot mower to a D8 Cat if he so desires.
He just asked if a 966 was "overkill" for his mower and we gave our opinions, which by the way, I still stand by.
Heck, the 966 has always been one of my favorite tractors of all time just because of the brute that they are.
Allan
Baelee05
01-21-2006 10:30:38
 Re: 966 for brushhog in reply to Allan in NE, 01-21-2006 05:35:57
Allan if you read my post I agree that the 966 may be overkill. So what? If he is mowing real tall tough cutting stuff that 966 will be just fine. If he were to go out and hook that tractor to a five bottom plow and use it like that he would stand a chance of a lot more repairs than the way he plans to use it. Granted if he can find a 686 or a 766 for the same money he might be better off. Around here those smaller tractors bring the same or more money than a 9 or 1066. For the way he intends to use it I think he will be just fine. A 966 is not that big of a tractor.
John A.
01-20-2006 21:11:15
Rifman, As Hugh, and Allan have said, I echo once more. Allan and I both presently have one. But we have larger acerage to to give thes ol girls a real work out. A 966 is NOT a tractor to Putter - around with and do light work. Extented running at half throttle will cause the engine to slobber oil from the exhaust and run down the manifold. Doesn't really hurt the engine all that much that I can tell. But a good dose if hard plowing at full throttle will cure it.
A 966 is better suited to a 15 ft batwing shredder than a 8ft 3pt lift model
A 60 horse tractor would be a better choice such as a 460/560. Small enough to trailer, large enough to put a loader on and do chore work. Run a baler, etc,etc. Hope this helps.
Later,
John A.
Hugh MacKay
01-20-2006 17:13:16
Rifman: Most folks are running 8' bush hogs with 60 hp or less. Big tractors are fine if you have the heavy work for them. Sure, you can buy them cheap and in decent shape. However, you know something, in 63 years I've never found a tractor that didn't break down. That usually requires a trip to the parts counter. Some of those trips with 100+hp tractors especially that hydro, could be damn hard on the bank account, probably twice what the tractor will cost you.
Did you read the article here at YT yesterday about folks waining on the tractor hobby and ownership of older tractors? Part of that is the fact that they buy big tractors, because they are cheap. I can take you to countless numbers of big tractors parked in the bush or back 40 out of sight and out of mind, and broke down. Why are they there? Simply because someone is either unable finincially or unwilling finincially to spend the dollars to fix them. Believe me, I farmed with big tractors, they can present you with 5 figure repair bills.
966 for bush hogging, yes if you have 500 acres per year to bush hog. By the way, I give this little lecture about once per month. Having a tractor to do your property work can be fun, don't let it make a slave out of you.
Larry806
01-20-2006 19:52:58
 Re: 966 for brushhog in reply to Hugh MacKay, 01-20-2006 17:13:16
"Some of those trips with 100+hp tractors especially that hydro, could be damn hard on the bank account,"
What hydro??? He clearly says NON HYDRO
Are you saying if he found a much higher priced 666 or 766 he would be better off? If the 9 is priced right I say go for it yeah they can cost money to fix but I ain't never had a dealar say your parts are free this time because you have " the right size tractor for the job".
Hugh MacKay
01-21-2006 02:46:49
 Re: 966 for brushhog in reply to Larry806, 01-20-2006 19:52:58
Larry: So I misread the hydro part of his post, let me assure you that changes very little of my text.
In my lifetime I've owned 16 farmalls, 1 Cockshutt, 1 Deere and 2 Cases, everyone of them bought either new or with less than 1,500 hours on them. The smallest was a Super A and the largest a 1066. If I were to do a bit of digging through my records I could tell you exactly what each and everyone of those tractor cost for repairs and to operate. I could further tell you exactly what the cost was per horsepower per hour.
To summarize I will tell you this, my 560D and 656D were the 2 most efficient tractors I ever owned. Each one went 10,000 hours with virtually no repairs, less than $1,000. for each. They would each crank out 60 hp on little over 1 IMP gallon of fuel per hour. I can tell you that when you step up to the parts counter, on average you will buy 656 and 560 parts for a fraction of the cost of any of the large chassis tractors.
Don't get me wrong the large chassis tractors can be quite efficient, but you've got to be using 100% of their rated hp all the time. I only ever started my 1066 for 5 jobs; those being 12 ton manure spreader, 20' disk, 25' cultivator, NH 890 forage harvester and a Dika Root windrower that I did custom work with. That Dika could make a 1066 suck back 10 gallons of fuel per hour.
My point has been "MATCH YOUR HP TO YOUR WORKLOAD". I do more work every year with my Super A than he'll do if he only hogged that 11 acres. Now I don't recomend the SA for hogging either, mainly because of offset takeoff. However there are many 40 hp tractors bush hogging 50 to 100 acres per year. Why, I can't tell you, myself if I were going to work more than a couple of acres it would have to be a money maker.
Larry806
01-21-2006 08:43:10
 Re: 966 for brushhog in reply to Hugh MacKay, 01-21-2006 02:46:49
"In my lifetime I've owned 16 farmalls, 1 Cockshutt, 1 Deere and 2 Cases,"
Well lets just say I've owned several tractors over the years
"I can tell you that when you step up to the parts counter, on average you will buy 656 and 560 parts for a fraction of the cost of any of the large chassis tractors."
I don't really agree with that. Parts for the 560 & 656 are going to keep getting harder and more expensive to get. So my point is the 9 can be a much better deal than a 666 or 766. I was looking for a 766 or 786 this fall to be a sprayer tractor. I bought a 1466 almost 7000 less than they wanted for a 786. I moved my 806 ( al most 20,000 hours on it) down to spraying and auger work & replaced it with the 14 in the field.
Neighbor wanted a White 105 to pull a 15 ft mulcher & drill with. We went to a sale and he bought a White 4-150 for over 7000 less than the 105. He used it for 10 years on the drill. With that light load he never had any repairs. He and I started working together and replaced the 150 with my 806 on the drill and I bought a 24 ft field cultivator for the White. with in 2 year we had repair on the 150.
Hugh MacKay
01-21-2006 15:59:04
 Re: 966 for brushhog in reply to Larry806, 01-21-2006 08:43:10
Larry: I see very clearly you are giving commercial farmer advice to a non commercial user.
One thing I've never seen is Farmall parts hard to find. I suspect you see only what you want to see.
Larry806
01-21-2006 16:24:50
 Re: 966 for brushhog in reply to Hugh MacKay, 01-21-2006 15:59:04
I don't think their is any difference. Getting the most value for the buck is where its at.
Well that's where your wrong! You wouldn't believe how many tractors go through my shop a year. The reply I get more and more from the parts guys " NA, discontinued or obsolete The IH dealer says it is going to get worse fast. I can't believe the number of parts I bought only months ago that I can't get today. It isn't any different at the Deere dealer either.
I think that's what some of us were trying to tell you
When I first posted on this board you jumped all over me because what I said didn't agree with what you thought on the subject and you were the one that HAD to be right. I'm not picking or trying to start anything but some people do have different opinions and that doesn't mean their always wrong
Hugh MacKay
01-21-2006 17:58:57
 Re: 966 for brushhog in reply to Larry806, 01-21-2006 16:24:50
Larry: Which hat do you wear anyhow?
Larry806
01-21-2006 18:23:02
 Re: 966 for brushhog in reply to Hugh MacKay, 01-21-2006 17:58:57
What do you mean?
Hugh MacKay
01-22-2006 03:15:11
 Re: 966 for brushhog in reply to Larry806, 01-21-2006 18:23:02
Larry: At 8:43 yesterday you were a farmer, and at 16:24 you were a shop owner so busy, I would not be able to imagine how many tractors went through your shop in a year.
Now I'm about to rebuild the engine on my Farmall 130. I have 3 different quotes on parts. Since I've retired, I have a bit of spare time and was thinking I'd buy another tractor to restore. I know where there is an 806 that needs engine work. I expect you will be able to find me a source of parts for the same price as my 130 per cylinder. I'm happy to know that, I was of the opinion 806 parts would be 3 to 4 times the cost of 130 parts per cylinder. This could be a money maker.
Larry806
01-22-2006 09:03:31
 Re: 966 for brushhog in reply to Hugh MacKay, 01-22-2006 03:15:11
I am a farmer may I ask with all you know why you aren't still farming?
I buy & sell tractors when were not in the field. around here a 9 or 1066 is a barn yard tractor for the big boys.
Now about the parts, you were talking about a 60 hp tractor vs a 966 I didn't realize a 130 has 60 hp you should come out quite well selling that alone & won't need to buy the 806
Hugh MacKay
01-24-2006 20:30:52
 Re: 966 for brushhog in reply to Larry806, 01-22-2006 09:03:31
Larry: Your part in this discussion has me convinced you know very little about Farmalls. Especially that last comment telling us a Farmall 130 is 60hp.
Took bit of time, did a little cruise through the archives, your questions of 18 months ago confirm what I am saying. Just 18 months ago you were asking very elementary questions about Farmalls. About the only responces you gave involved what they sold for at the last auction, I found no technical advice.
Checked out prices on piston and sleeve kits with gaskets. Farmall 130- $100. per cylinder, Farmall 656- $125. per cylinder, 806 and 966 $200. per cylinder. Took a glance at other items and the spread is about the same. Basically this agrees with my many years of record keeping. You always show greater profits when underpowered on the farm. That little 130 gasser is going to run about 4,000 to 5,000 hours on a set of pistons and sleeves. Diesels on the other hand will run 10,000 hours on a set of pistons and sleeves. Most of the diesels I've seen do 10,000 hours clocked those hours very quickly, about 800 or more yearly. I have seen a lot of diesels doing 300 hours per year require pistons and sleeves every 5,000 hours. Looks to me like you size the tractor to the work.
Another matter one has to be concerned about with 66 series and later diesels is cavetation with these wet sleeve engines. Water filters will slow it down, however they will not eliminate cavetation. Without the filter the sleeves will be done in 8 years and the filter it will double t0 16 years. I personally think these 66 series engines could reasonably go 15,000 hours between rebuilds, but the tractor must be clocking 1,000 hours per year. Highly unlikely bush hogging 11+ acres per year. So why don't you just leave the advice on which tractor to buy, to the guys who bought these tractors new 30 to 40 years ago, kept meticulous records on them for many years.
I always asked a mechanic for technical advice, but I never asked him to do my record keeping.
Hugh MacKay
01-22-2006 03:14:49
Larry806
01-21-2006 08:41:52
I don't really agree with that. Parts for the 560 & 656 are going to keep getting harder and more expensive to get. So my point is the 9 can be a much better deal than a 666 or 766. I was looking for a 766 or 786 this fall to be a sprayer tractor. I bought a 1466 almost 7000 less than they wanted for a 786. I moved my 806 ( al most 20,000 hours on it) down to spraying and augar work & replaced it with the 14 in the field.
Neighbor wanted a White 105 to pull a 15 ft mulcher & drill with. We went to a sale and he bought a White 4-150 for over 7000 less than the 105. He used it for 10 years on the drill. With that light load he never had any repairs. He and I started working together and replaced the 150 with my 806 on the drill and I bought a 24 ft field caltivator for the White. with in 2 yeard we had repair on the 150.
Allan in NE
01-20-2006 17:39:36
Gotta agree with Hugh and this is only an opinion. But a big tractor is meant for big work.
Not like I do once in awhile, diggin' postholes. A plumb crazy waste waste of fuel and wear and tear on an expensive machine that is tied to a chore that could easily be handled by another tractor 1/4 it's size.
For what you want to do, a 60 horse small chassis IH could handle those chores with one hand tied behind it's back.
Secondly, tractors are made for work, and they should be pushed to their limits once in awhile to keep 'em in top form. They just run better when they're workin' hard.
Like I say, just my opinion,
Allan
Erik in WI
01-20-2006 15:47:00
The 966 is the best 100 horse tractor I know of. I don't think it is overkill, not if you have hills like we do! Look to see if it has a water filter, which will be on the right side of the motor. That little item will save you lots of trouble. If you know the serial number (right behind the motor, left side) you can find out what year it was built, look for a later model tractor as they made many design changes for the better. I dont consider them a high maintenence machine, just use IH engine oil, and Hytran in the rear end and they will last forever
starting s/n for years
1971 7101
1972 11815
1973 17794
1974 22526
1975 28119
1976 31772 (will have black decals)
