Will M Belt Pulley Fit a Super M
David Kronwall
01-20-2006 18:58:59
I bought my '53 Super M without a belt pulley. I've found a pulley on this site that came off an M, 11" x 7-1/2", that the owner says WILL fit my Super M. I'm just checking the forum here to see if others have experience with this and agree that it will fit. If so, I'll probably buy it. Thanks, guys, in advance.
Haas
01-21-2006 05:39:54
 Re: Will M Belt Pulley Fit a Super M in reply to David Kronwall, 01-20-2006 18:58:59
Yes, it will fit. However, be aware that there are multiple sizes of belt pulleys. If it is just for show does not matter. If you are going to use it though, you need to size the pulley diameter according to the speed you want your implement to run and the width according to the width of the belt you will use. I believe the pulleys came in two different widths and diameters from 7 inches to 13 inches. The mounting is the same for all of them on the H and M tractors and also W-4, W-6, as well as the super series of those tractor, etc.
LEsd
01-20-2006 19:08:28
You will not have any problems It will fit.
David A. Hodson
01-20-2006 19:08:01
it should fit same housings. David
