antique tractor screensaver?
Ronald
01-21-2006 07:37:06
Does anybody know a link to where I could find an antique tractor screensaver? Preferable Farmall but I could settle for all brands. I've done some searching but all I found were tracor pulling savers.
Thanks Ronald
Ronald
01-21-2006 19:53:52
 Re: antique tractor screensaver? in reply to Ronald, 01-21-2006 07:37:06
Thanks I didn't realize you could choose just one folder and not all of my pictures.
Ronald
Roger46
01-21-2006 18:34:10
Ronald, I did like the others below said. I took a bunch of pictures of my tractors and others I have taken and put into "My Pictures" file and now have a screen saver with my own pictures. Roger
Buckeye
01-21-2006 12:51:28
I have Windows XP and made my screen saver from a picture I scanned of me harvesting wheat with a 1946 John Deere A and 12A combine.
little john
01-21-2006 10:32:48
I have a Macintosh and there is a similar procedure to the one below for making a screen-saver.
williamf
01-21-2006 09:32:08
I don't know for sure how it'll work with other operating systems, but if you use Windows XP you can make your own.
Create a new folder in My Pictures and name it, for instance, "Tractors."
Go to the Tractor Photos gallery on the left of this page and open a picture you want. Right click on the image, click on Save As. In the pop up, browse to the folder you created and save it there. Repeat, dozens of times if you want. After the first one it'll select that folder again until you tell it to stop.
Then open Control Panel, and Display. Open Screen Saver. Select My Pictures Slide Show. Click on settings and Browse to the folder you created. (If you leave it on My Pictures it'll show you everything in that folder.)
The other settings can change if you want, they're simple.
Good Luck, Wm
