300 overhaul started / TA question as well
Rick/ Oasia ID
01-21-2006 15:42:53
I pulled the head today (169 engine)visually looks ok, a little carbon but not to bad. going to take Tractor Vets advice and do a complete overhaul,pistons, liners, bearings,valve job ect ect. I got the wide front off as well and pulled the pan. #1 rod bearing is completly gone so i'm gonna need a new or different crank. I didn't see where these guys sell cranks any ideal where to start looking. ( i rather not weld and grind this one if i don't have to) The TA lever and linkage was missing from the old girl when i got her, i assume it's been welded up or something but now would be the time to fix it if i'm ever going to. I'm hoping Tractor Vet or someone can tell me if it's likely to be to big/complicated a job for a novice like myself. i seen they sell rebuild kits for it for around 200.00 Thanks for any advice
Rick/ Oasis ID
01-21-2006 17:01:15
 Re: 300 overhaul started / TA question as well in reply to Rick/ Oasia ID, 01-21-2006 15:42:53
Thanks ya'll The moneys not a big issue or should i say it can be overcome, is The TA something i can tackle or am i better off just leaving it alone. I don't do any heavy farming pull around my brush hog, clean corrals, drag around a little gravel and use the loader.
Kelly C
01-21-2006 17:07:37
 Re: 300 overhaul started / TA question as well in reply to Rick/ Oasis ID, 01-21-2006 17:01:15
Seeing as you have to motor area cleared. TA would be a peice of cake.
If your interested in seeing what it looks like in there. Check out my web site.
Find the section for Farmall 400 click that then find the TA section in there.
300 is the same only smaller.
Kelly C
01-21-2006 15:59:45
Piston sleeve kit= $280 + or -
Valve job = $400 +or-
Reground crank w bearings= $450 +or-
Gaskets and seals $100 + or -
Rebuilt TA $399 plus $100 core.
TA seal kit $65
New fluids, Oil, Hytran ect $150 + or -
Repairs for broke bolt ect $45
New bolts ect $30
Did I miss any thing?
Drew Becker
01-21-2006 17:37:47
 Re: 300 overhaul started / TA question as well in reply to Kelly C, 01-21-2006 15:59:45
You might just as well resurface the flywheel and put in a new clutch disk and throw out bearing. Also have the pressure plate surfaced.
Must Add
01-21-2006 16:17:22
Better go 15% more to donate to preacher as you will learn new words!!
