Help me.. Crank Pulley
Kelly C
01-22-2006 11:50:14
Hows this come off? I removed the bolt and the washer. Is this one peice pulley or 2? Didnt want to put too much pressure and break some thing with out knowing what I am doing :-)
third party image
third party image
El Toro
01-22-2006 19:40:36
 Re: Help me.. Crank Pulley in reply to Kelly C, 01-22-2006 11:50:14
Do you see anything that looks like a tapered ring
inside the damper? The 674D used this setup.
Only needed a pry bar to remove the damper. The pulley had a dowell pin too, to keep it in time.
Hal
MN Scott
01-22-2006 20:01:24
 Re: Help me.. Crank Pulley in reply to El Toro, 01-22-2006 19:40:36
Only german diesels used that ring setup.
the tractor vet
01-22-2006 14:21:18
Like ya been told clean out the bolt holes and get a bigger puller sometimes there on real tight and it is all my ten ton puller wants .
John In Iowa
01-22-2006 13:35:24
Need a bearing puller. Clean the holes out in front the pulley and use long bolts to hook it up the puller.
John In Iowa
williamf
01-22-2006 12:18:24
I'm no help.
If you've got it that far down could you just leave the pulley on the end of the crankshaft when you take the caps off the mains?
MN Scott
01-22-2006 12:17:42
Can you clean those holes out in front? I think they are treaded and you use a harmonic balancer type puller same as a car engine. Other wise your puller will work if its not the rubber ring harmonic balancer type.
