selective lift control valve SMTA
VOLfarmall
01-23-2006 11:19:09
I have found a selective lift control valve for a SMTA this valve has one handel with 3 slots then it has a little thum control valve with 2 positions Can anyone tell me how this works and what it is for? thank you
Hayfarmer
01-23-2006 22:24:21
 Re: selective lift control valve SMTA in reply to VOLfarmall, 01-23-2006 11:19:09
On the SMTA with the selective control valve you can use the lift all valve or the 2 way valve but not both at the same time. The thumb control is to lock the control handle so you can use the lift all valve, the lift all has a similar locking device to hold it closed to use the 2 way valve.
