Re: Painting help
BillyinStoughton
01-23-2006 14:30:21
First verify that you are using the correct pressure for the gun you are using. The next thing to conquer is the patience it takes for a gloss finish (correct preperation of the metal, primer, sanding, tack, color, and final coats, etc). Also be sure that you are using the correct amount of reducer and hardener for your spraying operation and paint you are using. Multiple light coats to establish a color base topped with a final coat that looks to almost run is the key. Patience is right up there with all the other ingredients! And by all means, talk to the guys at the body shop! H*ll...they do it for a living and most of them are willing to answer some questions for free! Good luck!
