Re: Fire Crater pistons in M
randy hall
01-24-2006 09:53:18
firecrater pistons didn't come out until '61, long after the last 450 was built. the ones ih designed for an 'm' fit an 'm' head fine.
ChadS
01-24-2006 12:53:07
 Re: Fire Crater pistons in M in reply to randy hall, 01-24-2006 09:53:18
I just went thru this,,, Had a M, put in a set of firecrater design pistons, (made for the late model heads) came from a late model tractor, used a 8060 head, and SLAP!! The pistons hit the head. Thats why the late model engines had the slant along the manifold side of the chamber, to make room for the new piston design. These were IH pistons, firecrater style pistons, in a M block with a 8060 head. I can show you a picture of them, the ones used inthe M, are totally different than the pistons used inthe 450. For one, the domes on the 450 pistons are spread out more over the top of the pistons,, onthe M design, they were a bigger dome, BUT, not spread out over the top of the piston. Which fit in the M heads,,, but not considered firecrater piston design. They were considered stepped head pistons. Big difference in the 2. SM-450 firecraters will not fit inside the M kerosine-gas heads, the M styles were stepped heads, even though they had a simular shape inthe dome, was much taller, and the dome is in one area of the pistons. Try this,, and its the exact same thing onthe SM,, put a H head on a Super H with firecraters,, Ill betcha a steak dinner, they will hit. Try the same with a SM with firecraters,, put on a M head, it will hit. Chad
Dave Slater
01-24-2006 17:22:45
 Re: Fire Crater pistons in M in reply to ChadS, 01-24-2006 12:53:07
IH made several different # of fire crater pistons.What Randy is trying to say is the ones they sold to fit SM did with no head change.80 percent of SM and MTA I have the head off has fire craters in them and 8060 or 8574 head.
Dave Slater
01-24-2006 17:21:01
ChadS
01-25-2006 14:18:07
 Re: Fire Crater pistons in M in reply to Dave Slater, 01-24-2006 17:21:01
Ive got a set of those in my Super M. 8574 head. Different dome shape that the ones used in the 450's. On the M i mentioned earlier, I pulled the sleeves out and put the 450 firecraters in, with the 8060 head. they hit. I agree with the older pistons, made for that head. Ive got 2 sets of those in 4 inch bore. They will fit the old heads, the dome shape is made for that style head. New style firecraters wont. I call the older style more of a stepped head, even though, the shape is simular to a firecrater.
