Super M Venturi
LumbrJakMan
01-24-2006 12:16:04
Whats the Number I wanna look for on a Bigger Venturi for my Super M Carb. I did the Larger drilling on the Jets , and Chad S mentioned a Larger Venturi , But not sure what size .
Thanks
LumbrJakMan
01-24-2006 14:57:53
 Re: Super M Venturi in reply to LumbrJakMan, 01-24-2006 12:16:04
Woo-Hoo, I got a # 29 in the Carb I just did over. Some days your the Windshield , some days your the Bug .... I do Stoneboat Pulling , so Im lookin for Low End Power ! Thanks Chad ...
ChadS
01-24-2006 12:37:10
Find a #29 for maximum low end torque, or a 33-35 for high rpm. The 29 was usually found in the C-264 (later models) and the C-281 was standard equipment. There is a few different ones listed in the parts book, but those work best on the dyno. Chad
champspa
01-24-2006 13:46:23
 Re: Super M Venturi in reply to ChadS, 01-24-2006 12:37:10
where can you get a #29 venturi?
ChadS
01-24-2006 16:15:28
 Re: Super M Venturi in reply to champspa, 01-24-2006 13:46:23
Early Super M's had a 27, then upgraded to the 29 after they changed the head, 400 had them in the 264 so did the 450 with the 281. Chad
