super c thermostat
R Fink
01-24-2006 12:32:01
rebuilding super c engine someone had removed the water pump in the past. I am now installing a water, do i need to have a thermostat and where does it go .
SCpuller1
01-25-2006 12:57:08
 Re: super c thermostat in reply to R Fink, 01-24-2006 12:32:01
I put together my Super C last year and I put a thermostat in it but I dont remeber any kind of retainer, do you guys think this will be a problem? It seems fine so far.
ACHodges1
01-25-2006 19:46:58
 Re: super c thermostat in reply to SCpuller1, 01-25-2006 12:57:08
It might be. The first one I installed I put the retainer against the thermostat but not in the groove. The pressure build up when cold and closed cocked it sideways in the water jacket.
achodges1
01-24-2006 19:24:40
You need to be sure the retainer is in the groove. Had to make a spacer for mine to keep both the thermostat on the shoulder and the retainer in the groove.
leon
01-24-2006 15:16:55
YOU'LL NEED TO ORDER BOTH THE 257 440 R91 THERMOSTAT AND THE 257 441 R2 THERMOSTAT RETAINER.
El Toro
01-24-2006 14:40:32
The thermostat should be in the engine water casting outlet. It should be just below where your top radiator hose is connected to the housing on the engine. Hal
