M wrist pins
lowdog
01-24-2006 18:47:07
MY M is a 1946 it has 1 inch wrist pins is this normal for this year M in the parts listing on this site it only ask if pins or 1 5/16 tryed to order engine kit from local dealer there book didnt list 1 inch pins any help would be appreciated
lowdog
01-25-2006 20:04:11
 Re: M wrist pins in reply to lowdog, 01-24-2006 18:47:07
thanks for yall,s help it dose have adapter bushing and it dose have the early ser # thats been a big help
Dave Slater
01-25-2006 06:05:59
Look on the connecting rod,if it has 5 numbers not counting suffix letters for the part # a thicker rist pin bushing (IH used to call them adapter bushings ) has been installed.If so all you have to do is get the bushing installed for the big pin.If the rod has a 6 number part followed by a suffix the rods have been replaced and you can only use small pin with this rod. IH used to sell several different sets of overbore piston sets with small pin for M and others that is the reason the adapter bushings were sold.
El Toro
01-25-2006 05:11:48
You should get new rod bushings with your sleeve kit like the kits from aicatalog.com. You need to check your tractor's SN when ordering a kit.
There's a kit for SN 278050 & up and another kit for SN's up to 278049. Hal
JRD(VA)
01-24-2006 20:10:59
You have to change the rod bushings for the bigger piston pin.
