slow hyralics on 544
joe sloniker
01-25-2006 16:06:36
I asked about the pump earlier and got confussed with an answer I got. My tractor has really slow lift speed on the arms and also when you have something heavy hook up to the remotes you have to rev the tractor up to lift them. Question is, is that the hdralic pumps or the hydralic supply pumps?
joe sloniker
01-25-2006 16:20:07
 Re: slow hyralics on 544 in reply to joe sloniker, 01-25-2006 16:06:36
Thanks for the help. I guess I need to make an appointment for the old girl.
the tractor vet
01-25-2006 16:13:01
with out putting your tractor on a Flowrater and seeing what the pump is doing then you can spend a bunch of time and money chasen a gost it could be this or it could be that until you see what it si doing then you have no idea.
Allan in NE
01-25-2006 16:21:22
 Re: slow hyralics on 544 in reply to the tractor vet, 01-25-2006 16:13:01
Yeah true,
But, if both systems are slow, maybe he ought to at least have a peek at the filter. It's the common denominator.
Allan
the tractor vet
01-25-2006 16:45:25
 Re: slow hyralics on 544 in reply to Allan in NE, 01-25-2006 16:21:22
I would assume that he had done that already . look how long you played with your Hydro and the time that would have been saved if you would have had the gauges and a flowrater but as of now you are the local GURU on hydros . the closest i have come to working on hydro's is doing a littel setup work on some 750 john deere dozers and it was a vary limited bit of work as i do not have the stuff to work on then but one of these days i'll come up with the test gauges and tach set up.
Allan in NE
01-25-2006 16:54:29
 Re: slow hyralics on 544 in reply to the tractor vet, 01-25-2006 16:45:25
I'm not the 'guru' on nothin'.
Just trying to help the guy, that's all.
Allan
joe sloniker
01-26-2006 05:55:43
 Re: slow hyralics on 544 in reply to Allan in NE, 01-25-2006 16:54:29
I have replaced the filter along with the oil as well, but there was no change at all.
