Paint code
Dennis McDaniel
01-25-2006 17:21:31
I have a Farmall Super M that I am restoring. I would like to get the paint code numbers for PPG paint and Dupont paint if anyone has them for the Farmall Red. I would like to get it mixed in acrylic enamal car paint to have a good finish. Thank you for your help.
the tractor vet
01-25-2006 19:23:12
 Re: Paint code in reply to Dennis McDaniel, 01-25-2006 17:21:31
Case I H 2150 with dupont 77s hardner and case ih thinner mix about a 1/3 of a can of the 77s to a gallion let set for 15 - 20 min light coatesallow 15 to 20 min between coates and put down 6-7 coates if done correctly you will be able to read whats on your hat at 10 feet away.
Brian Schmidt
01-26-2006 08:40:38
 Re: Paint code in reply to the tractor vet, 01-25-2006 19:23:12
People glow on this site about IH 2150 paint. I thought it was greatest thing I ever used when I painted my C 5 years ago. I even though about repainting my truck with it.
However, a couple years down the road, fuel, coolant, oil stains are horrible. I even can tell a difference in the color of the block to the color of the clutch housing. The block has turned more orange than the rest of the tractor.
I think what people like about it is that it is cheap. You cannot expect it to last very long if you use it like a tractor. If you just show it, it may be fine. But if I were showing one only, I would still want automotive paint because I can make it shine better and clear over the decals to make it a uniform surface.
CNKS
01-25-2006 17:30:01
PPG 71310, DuPont 96766. 71310 may be more orange than you like. If all you are going to use is acrylic enamel, you might consider Case-IH 2150. It is supposed to be an acrylic modified alkyd enamel, probably as good or nearly as good as acrylic enamel. I say "supposed to be" because I bought a quart of it and it just said enamel on the can, I have seen gallon containers had acrylic modified on it. I bought it to get the right color for PPG acrylic urethane -- had to change the toner ratio.
Dennis McDaniel
01-25-2006 18:16:09
 Re: Paint code in reply to CNKS, 01-25-2006 17:30:01
Thank you for your response.
