Torque specs for farmall f-12
DW Miller
01-26-2006 07:13:56
looking for the torque specs for a farmall f-12, rod bearings, main bearings, cylinder head
Bruce from TX
01-26-2006 17:44:08
 Re: Torque specs for farmall f-12 in reply to DW Miller, 01-26-2006 07:13:56
Head bolts. 85-95 Rod caps. 40-45
Farmallgray
01-26-2006 17:28:12
There aren't any torque specs for them. Or at least the service manuals don't give any. Check with a local bolt supplier for a standard bolt torque chart. The SAE gives standard torque specs for each size of bolt. You may even be able to find the chart on line. Do a search under "bolt torque specs".
