Electronic ignition for a M
T.B.W.
01-26-2006 11:51:21
When you put the pointless ignition in, do you put the plastic dust cover back in the distributor?
i4guy
01-26-2006 20:00:14
 Re: Electronic ignition for a M in reply to T.B.W., 01-26-2006 11:51:21
the dust cover will not fit with electronic ignition because the pickup sets up to high
Hayfarmer
01-26-2006 18:19:15
The instructions with my EI said to not use dust cover, not sure why but figured they knew best. Is your M converted to 12 volt, negative ground? Be sure to use right kit for voltage and ground.
John T
01-26-2006 13:04:35
TBW, As long as it still fits, I would use it to keep dust away from the magnetic pick up unit as posible. I havent any idea how much rooms under the dust cap on your particular distributor, but so long as the pickup unit isnt taller then the old points n condensor, I see no reason not to still use it. When you switch to an electronic switch, I HIGHLY recomemnd the use of a high energy coil to get the most bang for the buck and utilize the full potential of the new switch.
John T
