serial ##
just
01-26-2006 15:52:33
i just got a farmall c BUT the serial number plate is missing , is there any other way to find year?? engine # is 17324. if that would be any help.. thanks for any help!!
CNKS
01-26-2006 17:09:01
 Re: serial ## in reply to just, 01-26-2006 15:52:33
The C engine serial is the same or very close to the chassis serial. Use casting codes to confirm that the engine has not been changed. It is likely a 1948.
ejr-IA.
01-26-2006 16:10:17
Look for casting letters on cast houseings in different locations of the tractor and post them here.We can get you close on the year.I think the first year for the C is 1948 cast letter r,49 s,50 t,51 u or w.
just
01-30-2006 07:54:32
 Re: serial ## in reply to ejr-IA., 01-26-2006 16:10:17
thanks! i found some casting numbers 351111-r1(9-28r),351131-r1(10-11-r),3512244-r-1 (10-29-r)hope this will help ?? thanks agin!!
