1066 PTO seal from AI - IaGary
Michael Sheik
01-27-2006 04:28:11
Gary,
You sent me information that A&I made a seal the went in from outside on bottom PTO shaft on 1066 to stop leak and save pulling PTO. I contacted A&I through one of their listed dealers and they responded that A&I informed them no such seal exists. You said you had one on your tractor. Do you have the part number. Maybe I could call them direct if I had the number to tell them what I want.
dwag
01-27-2006 10:11:53
 Re: 1066 PTO seal from AI - IaGary in reply to Michael Sheik, 01-27-2006 04:28:11
HY Capacity also has seal/adaptor you are looking for. Part# 830470. 1 800 247-1824. We have put several on.
IaGary
01-27-2006 05:47:26
Michael My supplier said the only place to get is Ag Parts, Part no.830626, phone 1 800 445 6698.
You may have to go thru a local dealer for Ag parts.
If you have trouble let me know and my supplier will have it shipped to you.
I will open my email.
Good Luck
Norm/Niagara Falls/Canada
01-27-2006 05:30:46
Can you make up an adapter that you could use a standard seal instead of the "special" from IH, If I knew the relative dimensions of the components, I could make it for you.
IaGary
01-27-2006 04:39:00
I will check with my supplier when he opens this morning and get all the information you need. OK
Check back in about 90 min.
