Power unit Horsepower
Ironhorse
01-27-2006 07:52:35
Can you tell me the horsepower of An U-240 power unit? And Confirm that it is a volt positive ground system.
Thanks
IronHorse
El Toro
01-27-2006 09:42:27
 Re: Power unit Horsepower in reply to Ironhorse, 01-27-2006 07:52:35
If that's the same engine that's used in the 240 tractor; I think it would be around 31hp. If the battery cables are still attached at the starter & ground; the ground cable should fit the large positive + terminal on a battery if it's using a positive ground. The negative terminal
on a battery is somewhat smaller than the positive terminal. Hal
