Starter Solenoid Update - 400D
Farmall Frank
01-27-2006 10:09:14
For those lending me assistance, the starter I have is a Delco 1108996, with some other numbers far to the right that are 7925, which is suspiciously similar to a solenoid number which I currently have that is 7951.
Like I said before, I have one coming in which I hope will work. With my current 7951, I had to tap a screw into the end of my plunger to even get it to work, because the plunger cone was more angled than the receiving end of the solenoid, preventing the tip from pushing the starter contact in the solenoid.
Thanks for any further suggestions.
Bob
01-28-2006 00:52:37
 Re: Starter Solenoid Update - 400D in reply to Farmall Frank, 01-27-2006 10:09:14
That starter is a Delco "30 MT" series.
AFAIK, 1108996 is the important number, I believe the "7925" is a date code, anyhow it has NO relation to the jobber # 7951 solenoid you have.
Now, I guess we know why it was chattering, if the plunger doesn't match the solenoid, and you had to modify it!
Hopefully, your new solenoid will solve the problem. I will look up some of these numbers at the shop tomorrow.
Dave Slater
01-27-2006 15:15:49
Tractor I have with same starter # as yours has a delco remy selenoid # 1118055 on it.Another one has a starter # 1113034 and has a different selenoid with a different connecting link to bendix engaging arm,can't find # on it.At first glance starters look the same on tractor.
