What do ya'll use for degreasing??
Ksfarmmer
01-27-2006 16:48:59
I'm wanting to clean the years of grease and grime off my Cub Lo-boy. What do you guys all use? Do you have to worry about taking off paint or messing up the wiring?? Thanks
Fancy Farm
01-29-2006 16:20:30
 Re: What do ya'll use for degreasing?? in reply to Ksfarmmer, 01-27-2006 16:48:59
dollar store oven cleaner and fresh air
Eastsider
01-29-2006 14:39:45
Lots of cans of Brake Cleaner....and a Wire Wheel on an angle grinder....and a putty knife and dental tools and small scrapers and screwdrivers....
Whatever you can scrape off, do that first, then some brake cleaner really will do wonders...it'll leave a nice surface.
Tom Graham
01-28-2006 16:14:10
Go to the nearest Dollar Store and buy the cheap buck-a-can spray oven cleaner. Spray it on, wash it off.
Haas
01-28-2006 13:34:59
Whatever you do, DON't use gasoline as one below suggested!! Here's my sequence. Scrape off all you can by hand and with a scraper blade and wire brush. Then use a pressure washer which won't get it all. You might want to reverse the above and use the pressure washer first. Next get some Purple Power or similar degreaser from AutoZone or Walmart. Use a spray bottle to apply. You may want to use a respirator, as the mist from this stuff is pretty rough. Let is soak for a time and use the pressure washer again. Then you can clean up any stuff left by hand with the degreaser, a stiff brush and just a water hose. Needless to say, cover engine openings and your ignition stuff to avoid getting water in them.
john d
01-28-2006 11:41:36
Large areas: pressure washer; if it's really bad and not aluminum, oven cleaner first.
Small areas: spray can of Gumout.
El Toro
01-28-2006 03:54:03
Try using some Dawn Power Dissolver and then use a steam jenny or a power washer. Hal
Nebraska Cowman
01-28-2006 03:29:14
I use kerosene and elbow grease, then finish with simple green and lots of water.
Andy Martin
01-27-2006 20:11:02
I use diesel and a stiff brush.
IaGary
01-27-2006 19:51:35
Steam cleaner
Randy-IA
01-28-2006 08:50:45
 Re: What do ya'll use for degreasing?? in reply to IaGary, 01-27-2006 19:51:35
For the entire tractor - steam clean if you have access to one . For parts or second choice for entire tractor - engine degreaser ( in the rattle can ) at the carwash . True steam cleaners are terribly expensive , the Hotsey brand washer we have at work is one , it'll heat water to over 220 degrees . It's hard to work with it when it's that hot as it takes paint off right now , right down to the bare metal . That's one way I stripped a crane boom a few years ago . You can rent portable units at constuction rental stores . Otherwise some stores sell a wand that you hook up to a air supply and the garden hose . They work pretty good if you can hook to the hot water from the house .
F-Dean
01-27-2006 18:27:58
It is hard to beat gasolene! Just keep it away from sparks and fire, especially cigarettes.
Wardner
01-27-2006 23:28:57
 Re: What do ya'll use for degreasing?? in reply to F-Dean, 01-27-2006 18:27:58
I know a guy who would not recommend gasoline. He was wire brushing with gas around his starter and shorted a live terminal. He was out of work for a couple of months with a burnt hand. His John Deere was destroyed.
gene bender
01-28-2006 05:18:01
 Re: What do ya'll use for degreasing?? in reply to Wardner, 01-27-2006 23:28:57
Do you suppose he will disconnect the battery next time?
