Farmall 560 oil filter troubles
Kevin Kostiuk
01-28-2006 15:13:05
I had to rebiuld the head on my 560 and just got it back together but I've got oil coming out of the top of the filter housing. I've got the bolt good and tight but it's coming out anyways. I took the guts out of the filter housing and cleaned everything up so I was kinda wondering if I possibly got something back together wrong or do I just need to replace the brass washer on top? I've got the thing assembled as follows from top down 1)bolt head 2)brass washer 3)filter housing 4)spring 5)large flat washer 6)o-ring 7) filter. Does this sound right? Did I miss something. Thanks for any help. Kevin K.
Brownie 45
01-29-2006 05:10:41
 Re: Farmall 560 oil filter troubles in reply to Kevin Kostiuk, 01-28-2006 15:13:05
Problems. Kindly disregard Two messages.
Brownie 45
01-29-2006 05:07:50
All replies are pertinent. If the holddown bolt is slightly too long, you might use two copper washers with permatex #2 on all surfaces. Copper washers are available at most auto supply stores.
Brownie 45
01-29-2006 05:07:29
Brownie 45
01-29-2006 05:07:11
Tim Shaw
01-28-2006 19:19:05
We had a couple of 460s that got to doing that so we just converted them to a spin on type filter. You can get the conversion kit from a CIH dealer.
Kevin Kostiuk
01-28-2006 19:04:55
OK, so it sounds like I"ve put it back together properly and just have a sealing problem. That"s the big thing I wanted to know. I"ll look at the seal and possibly make a couple of new ones. Thanks for the help.
billde
01-28-2006 16:56:35
Iagary is correct copper and brass are annealed by quenching in water.
billde
01-28-2006 19:14:45
 Re: Farmall 560 oil filter troubles in reply to billde, 01-28-2006 16:56:35
Sorry gave the right answer wrong credit, Jim is correct, heat & quench.
IaGary
01-28-2006 15:21:05
Heat the washer real hot and let it cool slow.
This will soften the washer and it will seal better.
Janicholson
01-28-2006 16:49:18
 Re: Farmall 560 oil filter troubles in reply to IaGary, 01-28-2006 15:21:05
No disrespect, but non-ferrous metals (for the most part) are annealed by quenching, not cooling slowly.
Checking the filter bolt for length in the housing to be sure it is not bottoming on the hole, or crud, or ?, is a good cheap idea.
Using a hand magnifier on the filter housing, and underside of the bolt head to see if there are scratches is next. Then use a thicker copper washer, with more compliance.
JimN
