IH 384 tranny fluid
morgan in flori
01-28-2006 19:04:52
just bought a 1982 international harvester model 384 with front loader. on top of tranny by gear
shift is a filler plug...how do i know when it has the proper amount of fluid in it.can't find a
dipstick or a plug on side of tranny to fill it up to?? loader pump runs off this fluid also it seems. thanks for any help. morgan
JB2
01-28-2006 21:27:58
 Re: IH 384 tranny fluid in reply to morgan in florida, 01-28-2006 19:04:52
Hi Morgan, the filler plug by the gear shift lever is for transmission and differential oil only. The level check plug for trans/diff is the right side of the transmission by the left brake pedal and the foot rest. It uses 80 or 90 wt gear oil.
The hydraulic reservior is under the seat and is filled by the plug on top of the casting behind the seat. If you have a loader there maybe a return hydraulic hose plumbed into this hole with a pipe T. The hydraulics require Hytran hydraulic oil.
From Operator's Manual:
Hydraulic Lift Housing Filler Plug
Remove plug and check oil level. Top up until the oil is level with top of housing.
JB2
