Hey international Guys need you help on a new piec
Ironhorse
01-29-2006 16:51:14
jusr got a International U-240 power unit. It has a Silver diamond Engine. In getting it home several hundred miles. I broke lose every piece of rust in the gas tank. and when i got home to start it to for my wife and neighbors the new engine it didnt go. so pulled the tank and cleand out the clogs. then on to clean the carb. As usual in my hurry to hear it run again forgot how many turn in and out. So what i need is the intial adjustment on this carb and looks like three screws I know one is high speed and one idle speed and i got one on the shaft the goes between the carb and gov. the setup look like whats on the older farmalls. I got it to run but only with the choke out. that for you help and also where to get a manula for this?
thanks
Ironhorse
El Toro
01-30-2006 06:18:21
 Re: Hey international Guys need you help on a new in reply to Ironhorse, 01-29-2006 16:51:14
You may still have some dirt blocking the fuel flow. Check for fuel flow at the carburetor inlet
should have a good flow from the tank. There may be a screen on the inlet to the carburetor that's
blocked with rust. If this carburetor has a main jet adjusting screw near the bottom of the carburetor it needs to be opened several turns.
Hal
Steven@AZ
01-29-2006 19:42:36
Lots of good info on the SD240 engine over in the L, R, S discussion forum at oldihc dot org
farmhand
01-29-2006 16:55:34
On most old farmall carbs the air and fuel is screwed all the way in then turned out four turns to start then fine tune.
farmhand
01-29-2006 16:55:25
