1066 - tractor Vet
Michael Sheik
01-30-2006 12:25:51
OK I called IH parts man and tried to get actuator pin with oring on it. he said on the 806 it had oring built on to the pin @ factory but on 1066 they did not have it available as a set from the factory. Either he is not worth his salt or ?????.
Sheepdog in NE
01-30-2006 16:48:27
 Re: 1066 - tractor Vet in reply to Michael Sheik, 01-30-2006 12:25:51
The 06's had the o-ring on the little pin. The 66's have a pin with no groove in it and the o-ring in the housing along with a backup washer and a small cup type thing to hold the o-ring and washer in place. If your 1066 had the pin with groove someone changed it over for some reason. The housing with the 4 balls is not the same either.
the tractor vet
01-30-2006 19:42:08
 Re: 1066 - tractor Vet in reply to Sheepdog in NE, 01-30-2006 16:48:27
There is a seiral # break on the 1066's that i had forgot about the earily ones were the same as 06-56 and the later ones used the pin with no O/ring on the pin but installed in the body with the back up ring. Hey i can't be wright 100% of the time i just fixed them as they came.
Aces
01-30-2006 14:21:15
Michael The o ring is not built on per say. It is so small that it is just about imposable to put on. I have tried it and I don't think ever got on on the piston.
the tractor vet
01-30-2006 12:32:18
Dad gum it i just did Eugenes 1066 last spring and Gause Equipment had it on hand. So this guy does not know what he is talken about because they are all the same. Till ya get into the 86 seires. But anyhow give it a try maybe you can get lucky .My luck runs so bad that if it was rainning wimmen i would end up with a good buddy on my lap.
